Polisy Rear Panel Connectors
Looking at the back of the POLISY box, Left to Right, the connectors are:
DB9 -- custom serial PLM Cable
RJ45 -- Main Ethernet connection to Polisy box
RJ45 -- ?
RJ45 -- ?
USB/USB - USB PLM cable, Z Wave Dongle, USB Hub to handle more than 2 USB devices.
Power Connector
What are the second and third RJ45 connectors are for?
Can you have both Z Wave and Zigbee dongles?
(Thanks)
(Thanks)
The software running on Polisy wouldn’t know a zigbee device. It’s only supporting the z-wave ZooZ stick as detailed elsewhere in the forum. You could have an external ZigBee hub and use a Node Server that supported it. I’m not sure what NS currently do that. Some others can answer that question.
