January 28, 201016 yr Hello aanthony, Is there a specific reason that you would like to start fresh? The best way is: 1. Factory reset your ISY 2. File | Restore Modem (PLM) 3. Add you devices using the first option (remove existing links) With kind regards, Michel What is the easiest way to remove all links to/from devices and the ISY?
January 28, 201016 yr Author Michel............ I have some bad links that I can't find. Don't know if they are scenes or programs so I thought a clean start and add them back one at a time would make sense.
January 29, 201016 yr Hi aanthony, Thanks. If you want to make it 100% clean then it would be best to also factory reset your devices. With kind regards, Michel
