Variable is showing both a switch and a light in GH
I have configured a state variable to act as a switch in GH. I have '0' as off and '1' as on. In the main GH screen it shows up as switch. If I long press the switch icon, it takes me to the device screen. On that screen it shows a dimmer control. I can select a dim value between '0' and '100' using the rotary slider. It will then update the state variable to the dim value I select. When I go into the device setting screen in GH, it is also listed as a switch.
This seems like strange behavior. Is this intended?
