"Setting Time From NTP" every 15 seconds?
I am not able to sync my isy/99 (v 2.7.9)(Windows 7) with an NTP server. Not a big deal to manually sync to my computer but, when I enable Syncing (set to sync every 24 hours) the event viewer shows activity every 15 secs:
Sat 01/30/2010 11:03:20 AM : Setting Time From NTP
Sat 01/30/2010 11:03:35 AM : Setting Time From NTP
Sat 01/30/2010 11:03:50 AM : Setting Time From NTP
Sat 01/30/2010 11:04:05 AM : Setting Time From NTP
Sat 01/30/2010 11:04:20 AM : Setting Time From NTP
Sat 01/30/2010 11:04:35 AM : Setting Time From NTP
Sat 01/30/2010 11:04:50 AM : Setting Time From NTP
Is this normal?
I'd like to sync automatically
I've tried numerous NTP server addresses: pool.ntp.org, time-b.nist.gov, etc. as well as the IP equivalents. I always get the
"[-60006] NTP server not responding" error
My computer syncs just fine to time-b.nist.gov
Any help is appreciated -
Hi Michel,
Yes, I do have a red exclamation point
Yes, I configured the ISY with a static IP
I just tried to send an email using smtp.comcast.net and I get;
[-50001] Mail server failure [AUTH LOGIN not Accepted]
I've double checked user ID / password
When I check "Use TLS" I get:
[-50001] Mail server failure [Connection failed]
Thanks for the help!
Hi tandar,
Thanks so very much for the info. In most cases, the routers do NOT relay DNS requests for IP addresses that they have not issued themselves (using DHCP). I think this is the case with your situation.
To rectify this issue, please use DHCP and then in your router, please reserve the IP address in the DHCP client table. This way, the router will never give your ISY a different IP address and it's happy that ISY is one of its DHCP clients.
Hi Michel,
Michel,
Once again thanks for the help. Unfortunately my router (Linksys WRT54g V5) does not allow for DHCP reservations. Any other suggestions are of course welcomed but I think I'll just have to live with the limitation for now.
On another note... It doesn't take a whole lot of reading in this forum to realize that you and Universal Devices have set the high water mark when it comes to support and listening to your customers. Two replies over the weekend are certainly not the norm for tech companies. I just hope that as your company continues to grow, you'll continue to place an emphasis on this level of customer support. This really differentiates you from most other companies and ensures long term customers.
Thanks Again
If I may add my two bits to the email issue.
In my case I had to be particularly careful with my mail server settings. I'm on Shaw in Canada and their mail server - which I assumed would be smtp.shaw.ca was actually gv.vi.shawcable.net.
The other thing that is significant is that some ISP's will require a user id/password from within their own network in order to use their SMTP server - in other words you don't have to use their email address for incoming mail - but you have to HAVE an email address with them that you can use to authenticate for their SMTP server to allow you to use it for outgoing mail. For instance - in my case - being on Shaw I don't use their email service - I use gmail. But in order to have ISY send email I opted to just create a shaw email address and use that to authenticate. You can use the gmail SMTP server as well but it requires changing ports and setting up TLS - too much fuss for something so simple.
If you're setting up your own static IP make sure you have the settings configured properly. The IP obviously must be right or you wouldn't be able to access your ISY. the subnet mask is usually 255.255.255.0 for most users. THe gateway should be the address of your wrt54gs - usually 192.168.0.1 or 192.168.1.1. The DNS Server is key - as ntp.pool.org won't resolve unless your ISY can find a DNS server. You can usually put in the same port as your gateway here as your router will usually forward DNS requests outside of the internal network to the WAN DNS server it obtained by DHCP. If that doesn't work then simply go to one of your machines that got an IP by DHCP, run the command prompt and type ipconfig/all. It will give you both a primary and secondary DNS server address that was assigned to you by your ISP. You can use the primary DNS server address in the ISY and it should be fine.
Anyways - long story short - you MUST fix your DNS issue first. If pool.ntp.org is not working then you have an issue with DNS - after all - pool.ntp.org IS there and there are no other settings required. Not seeing it is an indication that you are not resolving pool.ntp.org to its physical IP address.
On the wrt54gs the status screen will tell you the IP of your DNS servers (usually 2 of them). Usually the router will be set up so that DHCP will assign all the correct settings for devices that are configured by them but not necessarily. To make life really simple just set up your ISY like this
note the IP it's assigned to
unclick automatic (dhcp)
put in the IP it already had in the IP address
put 255.255.255.0 in the subnet mask
put the address of the wrt54gs in the gateway field (192.168.0.1?)
put the DNS server address that you got from the status screen of the wrt54gs into the DNS field
http port is 80
https port is 443
Once your ntp is working you know your DNS is working and THEN you can work on the potentially more complex issue of your mail - though it'll probably start to work too then.
Oh.. and the wrt54gs is a great router but the firmware sucks. Check out the Tomato firmware for it - it's a WORLD better and it's free. http://www.polarcloud.com/tomato
Hope this helps,
mark
Problem solved
I finally got got some time to look at the issue a little closer. I tried a higher IP address as suggested - no luck.
After reading through Mark's detailed response (thanks BTW) again, I decided to go back to basics and check everything. I realized that I had the wrong Gateway! Once I put in the router as the gateway, everything works!. Syncing to the NTP server and emailing just fine.
Thanks again
Tom
