Posted February 2, 201015 yr What are the current issues with the motion sensors? What are the fixes and are there going to be any enhancements with 2.7.11?
February 3, 201015 yr Hi C Martin, The issue is that you cannot add Motion Sensors using "remove existing links". You can, however, add them using "add existing links" if and only if you have already factory reset your Motion Sensor. This has been fixed in 2.7.11 and there are no enhancements. With kind regards, Michel
February 3, 201015 yr The only other issue I can think of is related to the fact that the motion sensor rarely sends the low battery notification.
