Could not login to the MyQ service with the specified credentials
@Goose66
Since my MyQ account has now been lined to Google for SSO with the MyQ app - what credentials am I using to access the MyQ Web Service via the PG3 node?
"Could not login to the MyQ service with the specified credentials. Please check the 'username' and 'password' parameter values in the Custom Configuration Parameters."
Scott
@MNicholes
Do you have 2 step authentication turned on for your Google account?
If so, I think this might be a case where you would need an app specific password for Google and apply that to the node server. Using your Gmail address as the user name and the app specific password for the node server setting.
Learn more about that from Google:  https://support.google.com/accounts/answer/185833
I don't use this specific node server and haven't changed the MyQ app to use my Google account so can't help specifically, but knowing that Google no longer allows unsecure apps to sign in with just user/pass you have to have the app specific password option. So think this would apply in this case. Give it a try. Let us know if it works.
