KL430 Strip Color Values
Been trying to figure out what format of color values to use; XY, HSV, RGB. HSV seems to sort of work but then I haven't found an HSL color chart that the ISY values correspond to.
Any help would be appreciated.  Thanks
Edited by vbphil
Typo: HSV not HSL
I'm using the NS but NRs would be good to use as well.
HSL is what Kasa natively uses, search Google and there's lots of info. I have one of those strips and last I tested it worked fine using any method. I can test again when I'm home at the end of next week. Are you using PG2 which is where this is posted, or PG3?
Sent from my Pixel 6 Pro using Tapatalk
ooops. I'm using PG3. I grabbed the wrong forum.
I'm using the HSV values in my AC. Using my finger in the Kasa App's color wheel makes it impossible to make our two strips exactly the same. The PG3 Node server makes it easy peasy.
I have 2 KL420L5's.
Edited by Athlon
@JimboAutomatesI studied up on the HSV color space. The Kasa NS works with HSV the only difference I see is in the max value for Saturation and Value (brightness). Mostly what I find online is their max values can be either 1 or 100 where the ISY uses 254. So, you can convert easy enough depending on what color chart is being used.
