Help! - Can't Login!
I just recieved my ISY-26 and I am anxious to make it work but I can't login.
It seems to get an IP address just fine.
It appears in My Network Places.
The application runs and I get a login prompt.
However, everytime I try to login (using amdmin,admin) it says "Negotiating Keys" and then I get this error:
"Socket Open Failed java.lang.NullPointerException"
I have unistalled the java jre and reinstalled from the supplied disk.
I have tried it in both IE7 and FireFox
I have even tried to login from another machine.
I ran the serial console and did a hard reset.
I am apparently communicating with it because when I try to login with the console open it displays this:
http://192.168.1.9:16613/>
H_ERROR:-13000 :
H_ERROR:-5015 :
LOGGER:-13000 : n=[null] c=[null] a=[null]
LOGGER:-5015 : n=[null] c=[null] a=[null]
H_ERROR:-10061 :
LOGGER:-10061 : n=[null] c=[null] a=[null]
H_ERROR:-10061 :
However, nothing has worked! I can't tell if it's the ISY or my PC but I have tried so many different PC configurations I am thinking its the ISY. I purchased the unit refurbished because that was all that was available, I hope that wasn't a mistake?
Please help?
-jd
Just some additional info...
I have also disabled my windows firewall and virus protection.
No change!
-jd
even more info...
Java logging on the client shows this as the exception:
network: Cache entry found
Exception occurred during event dispatching:
at com.universaldevices.upnp.UDProxyDevice.expireSessionKeys(Unknown Source)
at com.universaldevices.ui.security.UserCredentialOperations.ok(Unknown Source)
at com.universaldevices.dialog.UDDialog.actionPerformed(Unknown Source)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.Dialog$1.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
:D Update: I have successfully logged into the device. I had to go to the console configuration and fix the IP address as opposed to what was provided through DHCP. Not sure why? If you have any ideas I would appreciated it.
-jd
I have McAfee and have never had to disable it.
jdva wrote:
Very Happy Update: I have successfully logged into the device. I had to go to the console configuration and fix the IP address as opposed to what was provided through DHCP. Not sure why? If you have any ideas I would appreciated it.
-jd
I am thinking router trouble. Sometimes a restart of the router can fix things. I'm glad you got past it.
So now that you are in, What do you think of the ISY-26? I was very surprised!
Rand
Hi Rand,
Long time no see!
I am very much surprised that you have not had any issues with McAfee. Is it an older version?
Thanks so very much,
-jd
Rand
Hello Michel,
Yes it has been a long time. No news = good news :)
I am using the latest McAfee (updated this morning) but it is not the AOL McAfee, or the Comcast McAfee, or any other * McAfee. I use the McAfee McAfee, if that makes a difference.
Thank you,
Rand
Hi Rand,
Yes, indeed no news = good news.
Have you tried upgrading your ISY lately using your McAfee? I am quite certain you're going to get "Invalid Length" ...
Please do let me know if/when you do,
As always, with kind regards,
Hello Michel,
Thank you,
Rand
I'm having the same issue. I just received my ISY from Smarthome today. Windows XP Pro SP2, Norton Internet Security 2008. I can telnet into the ISY just fine, UPnP is fine and the app opens up, but admin/admin login just results in NullPointerException Socket Closed. I have tried disabling all Norton protection to no avail. Perhaps I will also have to try fixing the IP address in the ISY.
Tom
Just as jdva reported, when I switched the ISY to a static IP address, suddenly I can connect through the app just fine.
Any ideas as to why a DHCP-provided address doesn't work? It doesn't make much sense.
tabraham,
With sincere apologies for a tardy repsonse.
This is indeed strange. We could've passed jdva's sypmtoms as one of a kind but now that we have two cases reported, we are going to do a root cause analyis.
Thanks so very much for bringing this to our attention,
Not that it helps with the DHCP problem but,
Hi Rand,
Hello Michel,
Thank you,
Rand
Updated to 2.4.15 14-Nov-07, no problemo 8)
Keep up the good work!
Rand
Hi Rand,
That's totally unbelievable but I am so glad that it works.
Thanks so very much for the update,
Hi Rand,
Hello Michel,
Thank you,
Rand
Rand
