Zooz outdoor motion sensor
With my Insteon motion sensors failing, I bought a Zooz ZSE29 v2.0 motion sensor.  I cannot get ISY to even see the sensor.  Is the sensor too new for the ISY Z-Wave 4.55.00 firmware to handle?
Probably not. Id make sure you are on the latest ISY firmware for your ISY which is 5.0.16C.
Yes, I'm on 5.0.16C.  I wish I could find an older Z-Wave motion sensor that I used to have to compare.  I've got a dog door setup that turns on the outside lights for 5 minutes.  Not so much for the dogs use but for the wife to watch the dogs...
The old Insteon sensors have started to randomly trigger.  Worse, when I disable the sensor, any programing related to the disabled sensor continues to function.  Which requires disabling the outside lights to get some sleep.
The Aeotec multisensor 6 and soon to be released multisensor 7 are fully compatible with the ISY and Polisy. I use several of them and have never had an issue.
  • 3 weeks later...
I have the ZSE29 v2.0, works great with my ISY994. It's the only motion sensor I can find that is rated for outdoor use.
Edited by Steve L
