Programs Not Running After 4.9.x to 5.3.4 Upgrade on 7/26/22 ***SOLVED***
Posting this for others that may run into this issue. I could not find this solution in the Forum...
Upgraded from 4.9.x to 5.3.4 on 7/27/22
Programs stopped working
Everything else except Programs seem to work fine (ie: scenes, Alexa, etc)
Note: there were green arrows on each of my Programs (it didn’t dawn on me what that meant!)
Rebooted ISY
Programs still not working
When I run a Program directly (ie: Run “If”, etc) it does not work
No conditions present at Top Level “My Programs” folder
Nothing is getting reported in the Summary section (ie: Last Run Time, etc)
All Programs show as Enabled
Solution
From Details I selected a Program and then clicked on Save Changes
The system went through and saved changes for all of my Programs
Tested multiple Programs and they all worked!
Solved by TVC15
@TVC15
Glad you were able to fix the issue. This issue is a known part of upgrading from 4.x to 5.x and part of why "Step 6" is written into the upgrade process in the release notes for 5.3.4 (probably appears in all 5.x update release notes).
Even in the "NOTES" section at the top of the release post references the manual intervention needed when going from 4.x to 5.x.
While you said you're all set, it is still important if you had any "Adjust Scene" programs that you check each of those individually (and update if/as needed).
Quote
Notes
-      Upgrading to this version may require a lot of manual intervention including verifying scenes, programs and program settings are correct.  In some cases it will be easier to rebuild your network.
