PG3 ELK Node server 3.4.9
The Polyglot Version 3 Node server for ELK Security Version 3.4.7 is released.  See the Release Notes  Please make sure your Polisy is up to date by running Upgrade Packages in the Admin Console -> Configuration -> System section.
See the README for more information, including information on moving from PG2.
If you have issues or requests please check PG3 ELK Github issues to see it has already been listed.  And if you want to thumbs up an issue I will try to prioritize fixing the ones with most votes.
Edited by JimboAutomates
Change to 3.4.9
@JimboAutomatesI restarted to update and now the node server will not start and keeps saying restart to update.  It won't let me upload the log package.
Edited by btreinders
@JimboAutomates
22-08-06 14:07:34,046 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/00:0d:b9:59:41:b0_9/elkm1_lib/message.py", line 48, in <module> 2022-08-06 14:07:34,047 MainThread udi_interface ERROR udi_interface:write: MsgHandler = Callable[..., None] 2022-08-06 14:07:34,047 MainThread udi_interface ERROR udi_interface:write: TypeError 2022-08-06 14:07:34,048 MainThread udi_interface ERROR udi_interface:write: : 2022-08-06 14:07:34,048 MainThread udi_interface ERROR udi_interface:write: 'ABCMeta' object is not subscriptable
2022-08-06 14:11:25,102 MainThread udi_interface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30
2022-08-06 14:11:28,819 MainThread udi_interface INFO __init__:<module>: UDI Python Interface for Polyglot version 3 3.0.47 Starting...
2022-08-06 14:11:29,015 MainThread udi_interface ERROR udi_interface:write: Traceback (most recent call last):
2022-08-06 14:11:29,016 MainThread udi_interface ERROR udi_interface:write: File "./elk-poly.py", line 10, in <module>
2022-08-06 14:11:29,018 MainThread udi_interface ERROR udi_interface:write: from nodes import Controller
2022-08-06 14:11:29,019 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/00:0d:b9:59:41:b0_9/nodes/__init__.py", line 4, in <module>
2022-08-06 14:11:29,020 MainThread udi_interface ERROR udi_interface:write: from .Zone import ZoneNode
2022-08-06 14:11:29,021 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/00:0d:b9:59:41:b0_9/nodes/Zone.py", line 6, in <module>
2022-08-06 14:11:29,022 MainThread udi_interface ERROR udi_interface:write: from elkm1_lib.const import (
2022-08-06 14:11:29,023 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/00:0d:b9:59:41:b0_9/elkm1_lib/__init__.py", line 2, in <module>
2022-08-06 14:11:29,024 MainThread udi_interface ERROR udi_interface:write: from .elk import Elk
2022-08-06 14:11:29,025 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/00:0d:b9:59:41:b0_9/elkm1_lib/elk.py", line 9, in <module>
2022-08-06 14:11:29,026 MainThread udi_interface ERROR udi_interface:write: from .areas import Areas
2022-08-06 14:11:29,027 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/00:0d:b9:59:41:b0_9/elkm1_lib/areas.py", line 7, in <module>
2022-08-06 14:11:29,028 MainThread udi_interface ERROR udi_interface:write: from .connection import Connection
2022-08-06 14:11:29,029 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/00:0d:b9:59:41:b0_9/elkm1_lib/connection.py", line 13, in <module>
2022-08-06 14:11:29,030 MainThread udi_interface ERROR udi_interface:write: from .message import MessageEncode, decode, get_elk_command
2022-08-06 14:11:29,031 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/00:0d:b9:59:41:b0_9/elkm1_lib/message.py", line 48, in <module>
2022-08-06 14:11:29,032 MainThread udi_interface ERROR udi_interface:write: MsgHandler = Callable[..., None]
2022-08-06 14:11:29,033 MainThread udi_interface ERROR udi_interface:write: TypeError
2022-08-06 14:11:29,034 MainThread udi_interface ERROR udi_interface:write: :
Hi Jimbo, Any idea what this error is in the log, thanks.
2022-08-18 15:03:02,006 ELK-23587 udi_interface.node ERROR node:setDriver: controller:ELK Controller Invalid driver: GV25
Rebooted this morning, error(s) still there.
2022-08-19 07:08:33,160 ELK-2049 udi_interface.node ERROR node:setDriver: controller:ELK Controller Invalid driver: GV25
2022-08-19 07:09:44,144 Command udi_interface.node ERROR node:setDriver: controller:ELK Controller Invalid driver: GV25
Confirm your on 3.4.8 and restart the NS and it won't show up again.
First I went to admin console and updated packages, then update ELK node server to 3.48, restarted ELK node server several times and this error is still present.
ERROR: 08/19/2022 14:14:14 See log for: ELK Controller: 'str' object has no attribute 'value'
http://udi-forum-static.s3.us-east-1.amazonaws.com/monthly_2022_08/2058014383_ELKnoseservererror.thumb.jpg.f5f9d3fad538d1fdf2c4c4cf0e7625eb.jpg
Please go to log page and download log package and send PM it to me.
Sent log to your PM.
Jimbo,
This error popped up this morning.
ERROR: 08/20/2022 00:00:03 See log for: ELK Controller: Unknown message AR: 009999160201000100
5 hours ago, pjjameso said:
Jimbo,
Thanks, that is benign, I'll add an ignore.  That message means the system was sending an alarm report to central station and can not be used by 3rd party applications like this.
Both issues fixed in 3.4.9.  Thanks for reporting.
Thank you for your quick response and resolution.
I updated to elk Node server 3.4.9   The elk Node server status in PG3 shows disconnected. When I try and access the log file using the PG3 GUI, I get a 404 not found error. I have tried to delete and recreate the elk Node server. I have rebooted my polisy box. I have tried all these things repeatedly. Now all of my node servers (not just elk) are showing disconnected status in the PG3 GUI.  I am running PG3 3.0.63, and IoP 5.4.4
I have made sure there were no pending updates on my polisy box as shown below.  Something is seriously wrong here but I don't know how to proceed:
[admin@polisy ~]$ sudo pkg update
Password:
Updating FreeBSD-base repository catalogue...
FreeBSD-base repository is up to date.
Updating udi repository catalogue...
udi repository is up to date.
All repositories are up to date.
[admin@polisy ~]$ sudo pkg upgrade
Checking for upgrades (0 candidates): 100%
Processing candidates (0 candidates): 100%
Checking integrity... done (0 conflicting)
Your packages are up to date.
[admin@polisy ~]$ sudo service udx status
udx is running as pid 1148.
[admin@polisy ~]$ sudo service isy status
isy is running as pid 1216.
[admin@polisy ~]$ sudo service pg3 status
pg3 is running as pid 794.
