I've got an ELK M1 panel installed at home.  It runs Honeywell wireless, so not too much plugged into the panel itself.
I received a TRANS/LOW BATTERY warning on the LCD (and associated beeping from the panel).  The battery is about 4 years old so I figured that's about right to replace it.  Purchased a new ELK brand battery (same one that was in there).
Out of the box the battery registers 12.6V.  Plugged into the panel it reads 13.2 / 13.3 V (on my multimeter).  However, the low battery warning returned withing an hour.  I've tried turning the system on/off with the new battery connected.  Tried leaving it off for a while with no battery.  Tried waiting until it does it's daily re-check at 4pm.  Tried running the system test/rested (Menu -> #8 -> #4, etc).  That comes back with a reading of 13.8 V.
However, I'm stilling getting the low battery warning on the LCD and the beeps.
Am I missing something in resetting this or anyone know what I could do to fix it?
It appears that the low battery is on a transmitter, not the battery that you replaced. Should be able to see which transmitter either on the keypad quickly or with the logs either on Elk RP or via keypad.
  • Like 1
Thanks.  Would you happen to know how to check it on the keypad (what steps or under what #/settings)?
Update for anyone searching in the future.
After some Googling, the error was a low battery in a wireless transmitter.  Turned out to be a glass break sensor had low battery.
In RP2, able to check the log and that showed which zone it was that had the low battery.
  • Like 2
