Reduce GUI field display to fit smaller screens
Hi, is there a way to reduce the size of the field display boxes in ISY Admin Console GUI? As it is I can only see all the the data when using my 32" monitor set to 2560 x 1440 resolution.
Below is what I see at 1920 x 1280 resolution. The following three fields are missing at the bottom. It only gets worse at lower resolution (that I sometimes need to live with when I VPN into a machine from elsewhere)
Alternatively, is there a way to select what the fields in the bottom few rows are so one could move less interesting data lower down?
23 minutes ago, bpwwer said:
This has nothing to do with the node server, it has no control over how the data is displayed in the AC.
Figured that might be the case but asked anyway in case there was something that could be done.
if you are running windows, lower your screen magnification temporarily until you are done using the admin console.
Admin console is based on some older monitor parameters that haven't progressed with the times, apparently.
2 hours ago, Javi said:
Have you tried UD Mobile? It allows for moving and hiding status values. Available on Android, iOS, and M1 Mac.
yep. use it all the time and do like it. I suppose I could open it up on the side while I'm doing Admin Console related stuff with the Tempest weather station. It's the shear number of fields that comes with the Tempest weather station that's the problem, which is not the worst problem to have.
