HoneywellHome node server has begun failing to connect: " No module named 'oauthlib' "
2022-08-23 09:05:25,442 MainThread udi_interface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30
2022-08-23 09:05:27,990 MainThread udi_interface INFO __init__:<module>: UDI Python Interface for Polyglot version 3 3.0.47 Starting...
2022-08-23 09:05:28,097 MainThread udi_interface ERROR udi_interface:write: Traceback (most recent call last):
2022-08-23 09:05:28,098 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/00:0d:b9:53:c6:f0_1/./honeywellhome-poly.py", line 9, in <module>
2022-08-23 09:05:28,099 MainThread udi_interface ERROR udi_interface:write: from api_helper import ApiHelper
2022-08-23 09:05:28,099 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/00:0d:b9:53:c6:f0_1/api_helper.py", line 5, in <module>
2022-08-23 09:05:28,100 MainThread udi_interface ERROR udi_interface:write: from oauthlib.openid.connect.core.exceptions import InvalidTokenError
2022-08-23 09:05:28,101 MainThread udi_interface ERROR udi_interface:write: ModuleNotFoundError
2022-08-23 09:05:28,101 MainThread udi_interface ERROR udi_interface:write: :
2022-08-23 09:05:28,101 MainThread udi_interface ERROR udi_interface:write: No module named 'oauthlib'
I did Upgrade Packages in the AC again. The four beeps occurred within a couple minutes, but I waited 30 minutes anyway. I restarted the HoneywellHome  node server in PG3. I am still getting the same errors listed above in the HoneywellHome log, and the HoneywellHome node server remains disconnected.
