The redirect URL provided does not match the redirect URL
Went through the setup procedure here:
https://github.com/dbarentine/udi-honeywellhome-poly/blob/master/README.md
When I go to https://udi-honeywellhome-auth.azurewebsites.net/ and enter the client ID and secret I get this error:
{"code":400, "message":"The redirect URL provided does not match the redirect URL registered for the app."}
Checked the URL twice, deleted the app and recreated twice.
Any ideas?
Solved by jkosharek
This might be something you need to open a support ticket for. I get the same error as you. Honeywell probably changed something and the UDI link is sending to a page that doesn't exist. I know I set it up in the past, but this time it did go to a bad URL as you say. I don't currently use this node server so not sure if it's working from my previous setup or not.
Submit a Ticket:       https://www.universal-devices.com/my-tickets
Email:                           support@universal-devices.com
FYI - @dbarentine or @bpwwer the link on the node server store doesn't point to the "read me" correctly for this node server. It's using the Polisy root address then "UniversalDevicesInc-PG3/udi-honeywellhome-poly". Different issue that can hopefully be easily fixed.
I figured this out, the call back URL needs a /auth at the end:
https://udi-honeywellhome-auth.azurewebsites.net/auth
That got it working for me.
