Changing Mutually exclusive buttons to scenes
I went to assign 2 buttons on my KeypadLinc as mutually exclusive in 2.7.11, and I didn't see a "Mutually Exclusive" button like was there in previous versions. I clicked on "Buttons Grouping" and found Mutually Exclusive sets there, but it says that feature is being done away with, and should be done via Scenes now.
I created a scene with the 2 buttons:
-Button C: Controller
-Button D: Responder
But how do you tell the scene to turn button D off when C is on? There's no way to set the on/off status like in regular scenes with actual Insteon devices being controlled. The buttons are simply status LEDs, like "Home" vs. "Away". They are not linked to a module. Thanks!
Hi CJVann,
You should be able to click on the controller button (say D) and then slide the slider for C to Off.
I had to delete the scene and make BOTH buttons controllers, otherwise there were no sliders to set on/off levels for the scene. Thanks!
