E-mail TLS 1.2
I was notified by Xfinity that email won't work any more unless TLS 1.2 is being used (vice 1.1).  I looked at my settings Configuration Email/Notifications Settings/Groups and there is only a checkbox to use TLS, it doesn't offer an option for version.
I have
V5.3.0 2020-10-01-14:39:56 for both Firmware and UI
Any advice, I want to keep Comcast, not use Gmail.
John
Solved by kzboray
OK, I checked this, both are set to 1.2.  Now I have to wait and see if it gets shutdown.
Thanks Techman for the info!!!
Regards,
John
This did not fix the issue.  It appears to affect messaging to a text number more than an email.  Ex. Xyz@txt.att.net
@JSchumann You will need to update your ISY994i to 5.3.4 which supports TLS 1.2.
The 5.3.4 Update is now available for the ISY994 product.
Notes:
  -  SSLv3 is now disabled. All models now support TLS1.2 and high grade cipher suites
  -  4.1.1 backups may corrupt Z-Wave configuration in case they are restored. 4.1.2 and above releases fix this issue
-  See our Wiki for additional information (e.g. Program Variables)
Please follow the upgrade instructions on the 5.3.4 page.
Edited by kzboray
Also note that email to text/SMS is extremely unreliable and not suggested as a method to be used for quite some time. Many carriers are delaying such messages or bouncing them all together.
If you're only relying on email to text for notifications you should consider alternate options. Many have been discussed through the forums so won't rehash what they are or how to set them up, but you should be able to find them easily.
But both above suggestions of updating to 5.3.4 are correct for the initial steps to resolve sending email with Comcast. I know others that do it without issue.
I'm running 5.3.4 and use text messages via ATT.NET and found it to be very reliable with no delays.
I have my timeout(ms) set to 6000
Upgraded to 5.3.4, still have the issue.
Text has been working fine until I got an email from comcast stating an application I am using is outdated will not be able to work if they do not update TLS 1.2.
Email is working fine (Comcast for both send and receive), also receive email on Gmail account.
Techman, what are your Server settings for outgoing?
I have:
smtp.comcast.net
Port 587 with TLS checked and
timeout 6000
sending to user@txt.att.net
Geddy, I will look for the alternate options.....
John
@JSchumann
I'm using the same email settings as you, however I don't have TLS checked and I'm using a different ISP, not Comcast
You might try increasing the timeout, and/or unchecking TLS
Edited by Techman
18 hours ago, JSchumann said:
Xyz@txt.att.net
you'll find that 10digitnumber@mms.att.net is better than 10digitnumber@txt.att.net, I've typed the reasons so many times that I won't repeat here, there in the forum at least a dozen times tho.
also as @Geddymentions email to text in general is not reliable.  Pushover or UD Mobile are better choices.
OK, I give up on text since the group deems is unreliable (although it has been fine for me for years).
I set up a UDMobile Notification.  Played with Program Variables and I think I get how it works.
So now I need to copy all my text notifications over to Network entries.
The notification seems to get delivered very quick.
Thanks for the help all!
Regards,
John
It seems to come and go. Some (like @Techman above) say it works well, but just as many (or more) have come here to complain about not getting mission critical texts for hours, days, weeks later. There have been news reports of email to text messages taking months to deliver. (Not just ISY notifications)
So, while is HAS worked well it’s a risky option that most would not suggest people use…especially alerts you might deem “mission critical”.
Glad you got UD mobile alerts working, and yes…they are very quick!
One thing people like about using Pushover is if you’re on iOS you can have different alerts and urgent delivery types that will come in through Focus times if necessary and setup that way,
Just some different options for new ways to get alerts.
Thanks Geddy, Yea, I am on Android so UD Mobile will be fine for me.  Appreciate all the help from the group.
Regards,
John
The solution is not to use text for notifications as it is slow and unreliable at times.  Lookup use of UD Mobile Networking or Pushover as described above.
This thread can be closed.
Regards,
John
