ELK node server support for thermostats?
5 hours ago, Jimbo.Automates said:
Is there anyone with ELK that would like the node server to support thermostats connected to your ELK?  It's on my list, but I don't rember anyone asking for it yet https://github.com/UniversalDevicesInc-PG3/udi-poly-ELK/issues/50
@Jimbo.Automates, I personally use ELK for security and fire alarm only.  I will generally prefer a direct connect to other devices, so I'm unlikely to use thermostats connected directly to ELK.
I use Elk for security and fire as well.  I use a different node server for my thermostat.
On 10/20/2022 at 3:55 PM, Jimbo.Automates said:
Ok, finally found someone emoji16.png Are you using ELK node server now?
Yes I am using the Elk Node server now. I am able to see the temperature of, say, "Area 001  Bathroom Chase Zone 15". But I cannot figure out how to embed that is a customized content for an email.
Sent from my Pixel 6 Pro using Tapatalk
Yes I am using the Elk Node server now. I am able to see the temperature of, say, "Area 001  Utility Room Temperature Zone 13". But I cannot figure out how to embed that in a customized content for an email.
The following does not work, for example:
The utility Room temperature is $(elk.zone.13.temp)
Should I use Alerts and Node Names?
