Ecobee NS - Stuck writing to one thermostat
Hi @Jimbo.Automates, I added a new thermostat to my home today so now I have have 3 ecobees.  The new one installed fine and showed up in the AC however it seems to be stuck with the green writing arrow to all nodes.
I'm wondering if I have confused things for the NS.  I moved the 'Greatroom' thermostat to the basement and renamed it 'Basement'.  I then installed the new one and named it 'Greatroom'.  If I look in the node list in the NS I don't see a 'Basement' node, it's still 'Greatroom'.
BTW, the new thermostat is the Premium model with air quality.  Thank for adding the support for that!
That's odd it's showing Writing, I have no idea how that would happen. ISY doesn't write to node server nodes.
The ecobee NS doesn't have the ability to rename nodes. I've been adding that functionality to my other node servers but haven't done it with ecobee yet.
Sent from my Pixel 6 Pro using Tapatalk
Do you think it's problem that 2 of thermostats have the same name on the NS side.  Maybe I should delete one and re-
add?
