PG3 Hue Node server needs almost-daily restart
Hue node server works well, but every other day it needs to be restarted in order for ISY (on Polisy) to continue working with it.  Any ideas? What other info can I provide to help? Thanks!
@kaplansa not noticed any issues with it and this is one node server I have run in PG3 for a while. Take a look at the logs to see if you can see any errors coming when you try to operate something.
Have you made sure you have an IP reservation for the Hue bridge in your router? Or else setup the bridge IP as noted in the settings (and mentioned in this post).
Just knowing what kind of errors are seen in the log will help with further troubleshooting.
