February 25, 201016 yr I updated my 99 to version 2.7.7. Everything works great except... Today I used my iPhone to access my ISY. I was able to log in OK and I then pushed "scenes" and tried to trigger a scene. Every time I tried a scene, I got a "Cannot Open Page". I waited until I got home and tried it "locally" through my router (again fron iPhone) but got the same message. I can log on the GUI via my computer OK and all works. Is this a bug or do I need to log in a different way than I did from 2.7.6? I am using https://MYDYNDNSADDRESS:MYPORT#/admin I then push "scenes" and get to, https://MYDYNDNSADDRESS:MYPORT#/scenes Thanks, I'm sure it is something simple. aLf
February 26, 201016 yr Hi aLf, This is quite strange! Actually, 2.7.7 fixed a long standing HTTPS issue we had with iPhones. So, the problem seems to be isolated to HTTPS/iPhone/Scene combination, correct? Would you be kind enough to try HTTP/iPhone (LAN)/Scene and let me know if that works? With kind regards, Michel I updated my 99 to version 2.7.7. Everything works great except... Today I used my iPhone to access my ISY. I was able to log in OK and I then pushed "scenes" and tried to trigger a scene. Every time I tried a scene, I got a "Cannot Open Page". I waited until I got home and tried it "locally" through my router (again fron iPhone) but got the same message. I can log on the GUI via my computer OK and all works. Is this a bug or do I need to log in a different way than I did from 2.7.6? I am using https://MYDYNDNSADDRESS:MYPORT#/admin I then push "scenes" and get to, https://MYDYNDNSADDRESS:MYPORT#/scenes Thanks, I'm sure it is something simple. aLf
February 26, 201016 yr Author Michel: You lost me. I have tried http://MYIPADRESS:MYPORT also, http://MYIPADDRESS:MYPORT/admin Neither allows me to get to the GUI. If I use https, I get into the GUI but when I push a scene button I get the failure. aLf
February 26, 201016 yr Author I just tried the https route again and tried to activate a light via the "Devices" page and also via the specific device page and neither of them worked either. Tim
February 26, 201016 yr Hi aLf, Questions: 1. you can accomplish all these using a regular browser at home, correct? 2. are you using any of the exotic interfaces such as TouchSwitch, ISY AJAX, or are you going to the HTML page directly? 3. for http, are you using your local area's ISY IP address (i.e. 192.168.x.x)? With kind regards, Michel
February 26, 201016 yr Author Michel: 1) Yes, everything works well through the computer on IE. 2) I'm only using the Safari in my iPhone, which worked on 2.7.6. 3) I tried http://192.xxx.xxx on the network places and have the same problem where it wont work. Tim
February 26, 201016 yr Hi aLf, Is there a possibility that your iPhone is caching your password and that it has changed? I just tested 2.7.7 with my iPod Touch and it works fine in both HTTP and HTTPS ... so, I am thinking that perhaps it's a cached password issue. Would you be kind enough to reboot your iPhone? With kind regards, Michel
February 26, 201016 yr Author I re-booted the iPhone this morning, no change. The password is the same as always and it isn't a password problem as I can get to the "scenes" and "devices" pages, but that is when the problem starts. Once into those pages, I get the error when trying to trigger the device or scene. Tim
February 27, 201016 yr Author Like every other issue, Michel is the man! Thanks for fixing it and sharing your precious time. aLf
