Wall Mounting Polisy w/ Wi-fi and ZWave in living space
My new townhome has sufficient living space, but significantly less utility closets and unused/dead spaces than my house did. I need to install my Polisy Pro (destined to include ZMatter board) in a central location in the home - perhaps a laundry room or hallway. It needs to be installed with an Insteon PLM and a small Li+ UPS (like the TalentCell unit).
WAF probably requires that it be installed inside a box, either one flush mounted in the wall or perhaps surface mounted (if in the laundry room). Has anybody had experience with mounting a Polisy with Wi-fi and/or Zwave radios inside an enclosure and/or wall mounting such in a visible location, and what solutions have you found?
Edited by Goose66
There are structured wiring enclosures made of ABS that shouldn’t interfere with radio, such as: Legrand - OnQ ENP3050-NA WiFi Compatible, Electrical Box Structured Media Enclosure, 30 inch, White https://a.co/dakJFt8
is that something like what you had in mind?
The OnQ boxes on Amazon were exactly what I was looking at. I was just wondering if anyone had put the Polisy, PLM, and maybe a UPS or transformer all in a box like that and what the performance was.
It would certainly be nice just to mount it on the wall open like @Geddy's picture, but I don't think that would fly with the wife - especially if it is in the hallway. I particularly like the built-in bubble level. Can't have the whole thing tilting and all the electrons pooling on one side! 😁
Edited by Goose66
those can be recessed so just the cover shows.  Then you can do like we do for the breaker box  and hang artwork in front of it.
I wouldn't think ABS would degrade the signal.  On my home assistant box i had to use 3 USB extension cord to get the zigbee dongle away from the Pi.  Not sure if it was moving it away and higher or changing the orientation that did the trick it works good tho, the only zigbee device it's driving is on the other side of the house.  I thought I was going to have to add a few lightbulbs as zigbee routers(repeaters) but just adding the 3' USB extention cord was enough.
  • 1 month later...
Got the shelf and installed (there were two in box like other Amazon reviewers mentioned). Worked out good. My Polisy is in basement furnace room and you can see PLM plugged in via the blue custom serial cable I made out of a Cisco console cable. Before this, I had polisy resting sideways on top of the UPS but with the ZMatter antennas that would no longer work.
C86C45A2-7ADA-47AF-8E59-081318BDBB77_1_105_c.thumb.jpeg.9c8e935fc29659b43a8f12589d4e80a9.jpegC3A2D80A-FB5C-436B-89DB-050F63D0310E_1_105_c.thumb.jpeg.a4065f167a43e2a9afd26dbfc2e76165.jpeg
Edited by brians
