Can't find Polisy
Polisy has been moved to a new network after a move.  Cannot find it anywhere.  ARP no mac address.  Can't add it in finder.  Nothing is really on Polisy.  Have tried to get back to factory defaults etc, no luck.  Any help would be appreciated.
Some things to check:
       Make sure your network has DHCP auto enabled
       Your ethernet cable must be plugged into the port closet to the DB9 connector
Wow after 4 hours it seems to have shown up.  Still not in finder.
Try removing power from the Polisy. If that doesn't work you can manually add it to the finder using the ADD button in the finder,
Edited by Techman
