Does this work in the same manner as the polyglot 2 sonoff node server?
Solved by DaveStLou
Thank you.
Can it be modified like the PG2 NS to add devices as well? I don't have PG3 yet so not sure if I can access source code for node servers or not
2 hours ago, beninsteon said:
Thank you.
Not sure what you mean by "source code for the node servers" but the configuration page on PG3 is the same as PG2. I use devlist but devfile is listed as an option - I've just never used it.
On PG2 I can see source code of node servers and change it as needed. This NS in particular is amenable to adding new device types if the source can be modified. Wondering if that's possible.
Just submitted a pull reqest to the PG2 NS on GitHub to allow direct access to high/med/low fan speeds through admin console and programs. Hopefully this can be merged for PG2 and updated in PG3 version as well.
You can find the PG3 version on GitHub here: https://github.com/exking/udi-mqtt-pg3
