Starts up but then shuts down.
I noticed this morning that the Virtual server says disconnected, not running. I hit Start and it starts up but shuts down right away.
This is in the main Log
Quote
12/18/2022, 08:11:02 [pg3] info: startNs:: Virtual
12/18/2022, 08:11:02 [pg3] info: startNs:: Virtual is valid
12/18/2022, 08:11:03 [pg3] info: checkLicense:: Virtual No license found for Free node server.
12/18/2022, 08:11:03 [pg3] info: startNs:: Virtual finished update check
12/18/2022, 08:11:04 [pg3] info: [Virtual(6)] :: Starting Node Server - Version 2.0.0
12/18/2022, 08:11:04 [pg3] info: startNs:: Virtual updating database (enabled, timestarted)
12/18/2022, 08:11:05 [pg3] info: startNs:: Virtual starting polls
12/18/2022, 08:11:05 [pg3] info: Starting Node Server Info timer 0
12/18/2022, 08:11:07 [pg3] info: [Virtual(6)] :: Exit cause code: 1 - signal: null
12/18/2022, 08:11:14 [pg3] info: [00:0d:b9:59:39:90_3] controller reporting command DOF
12/18/2022, 08:12:14 [pg3] info: [00:0d:b9:59:39:90_3] controller reporting command DON
this was in the virtual Log
Quote
2022-12-18 08:11:06,927 MainThread udi_interface.interface INFO     interface:__init__: Connect: Network Interface: {'addr': '192.168.1.158', 'netmask': '255.255.255.0', 'broadcast': '192.168.1.255'}
2022-12-18 08:11:06,931 MainThread udi_interface      ERROR    udi_interface:write: Traceback (most recent call last):
2022-12-18 08:11:06,931 MainThread udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/000db9593990_6/./Virtual.py", line 1105, in <module>
2022-12-18 08:11:06,934 MainThread udi_interface      ERROR    udi_interface:write: polyglot.start('2.0.0')
2022-12-18 08:11:06,935 MainThread udi_interface      ERROR    udi_interface:write: TypeError
2022-12-18 08:11:06,935 MainThread udi_interface      ERROR    udi_interface:write: :
2022-12-18 08:11:06,936 MainThread udi_interface      ERROR    udi_interface:write: start() takes 1 positional argument but 2 were given
I don't know how long it's been broken as I'm currently using it only in the summer months mostly.
Any ideas?
Solved by vbPhil
@Javido you have any knowledge of the Virtual node server and why it isn't working for me anymore?
@Michel KohanimAny luck rousting the developer to take a look at this? I wonder if the problem is isolated to my install or is it global?
just FYI.. i use this NS and its been working for me on a polisy....
have you tried reinstalling it? i once had a NS giving me fits and i uninstalled it and reinstalled into a different slot and it worked fine after that...
not much help but maybe something...
I've considered that. But didn't want to lose all of my settings for switches I've created. I will try that as a last resort. I have a service ticket in on it but so far, the developer is missing in action.
got tired of waiting for help. Deleted the Virtual server and re-installed it. Re=entered all the node configurations and fixed everything in IoX. Seems to be okay once again.
sorry i couldnt be more help.. but glad you got it going again.
