Bug on setup? Configuration help not showing until all data is entered and the node server connects
Greetings;
Since I had a rather painful migration, I experienced this several times.
After installing MQTT node server, when you start configuring it, all fields are blank and no CONFIGURATION HELP is given. fortunately I had screenshots from PG2, so I just added the fields as necessary. Once set up and SAVED, the HELP pops up.
On one of the last re-installs (I had too many to count), I tried entering and saving one field at a time. No dice. It wanted all of the fields necessary to connect. Then it splashed the HELP.
It all works splendidly. Thanks @xKing.
Screenshot when you first enter configuration.
and only once it connects with all the necessary info, the config help shows up.
Cheers
Edited by TriLife
added missing information
