Not discovering on eisy
@xKing
Hi
I have moved the LiFX node server onto the eisy and found that it no longer will do a discovery. Just shows the following errors when discovery initiated. Any suggestions.
Thanks Gary
023-01-01 13:17:46,081 Command    udi_interface.interface DEBUG    interface:_parseInput: DEQUEING command
2023-01-01 13:17:46,081 Thread-2527 udi_interface      INFO     lifx-poly:_discovery_process: Starting LiFX Discovery thread...
2023-01-01 13:17:46,082 Thread-2527 udi_interface      ERROR    udi_interface:write: Exception in thread
2023-01-01 13:17:46,082 Thread-2527 udi_interface      ERROR    udi_interface:write: Thread-2527
2023-01-01 13:17:46,082 Thread-2527 udi_interface      ERROR    udi_interface:write: :
2023-01-01 13:17:46,082 Thread-2527 udi_interface      ERROR    udi_interface:write: Traceback (most recent call last):
2023-01-01 13:17:46,082 Thread-2527 udi_interface      ERROR    udi_interface:write: File "/usr/local/lib/python3.9/threading.py", line 980, in _bootstrap_inner
2023-01-01 13:17:46,083 Thread-2527 udi_interface      ERROR    udi_interface:write: self.run()
2023-01-01 13:17:46,083 Thread-2527 udi_interface      ERROR    udi_interface:write: File "/usr/local/lib/python3.9/threading.py", line 917, in run
2023-01-01 13:17:46,083 Thread-2527 udi_interface      ERROR    udi_interface:write: self._target(*self._args, **self._kwargs)
2023-01-01 13:17:46,084 Thread-2527 udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026038_7/lifx-poly.py", line 206, in _discovery_process
2023-01-01 13:17:46,084 Thread-2527 udi_interface      ERROR    udi_interface:write: devices = self.lifxLan.get_lights()
2023-01-01 13:17:46,084 Thread-2527 udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026038_7/.local/lib/python3.9/site-packages/lifxlan/lifxlan.py", line 42, in get_lights
2023-01-01 13:17:46,084 Thread-2527 udi_interface      ERROR    udi_interface:write: self.discover_devices()
2023-01-01 13:17:46,084 Thread-2527 udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026038_7/.local/lib/python3.9/site-packages/lifxlan/lifxlan.py", line 50, in discover_devices
2023-01-01 13:17:46,085 Thread-2527 udi_interface      ERROR    udi_interface:write: responses = self.broadcast_with_resp(GetService, StateService,)
2023-01-01 13:17:46,085 Thread-2527 udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026038_7/.local/lib/python3.9/site-packages/lifxlan/lifxlan.py", line 234, in broadcast_with_resp
2023-01-01 13:17:46,085 Thread-2527 udi_interface      ERROR    udi_interface:write: msg = msg_type(BROADCAST_MAC, self.source_id, seq_num=0, payload=payload, ack_requested=False, response_requested=True)
2023-01-01 13:17:46,085 Thread-2527 udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026038_7/.local/lib/python3.9/site-packages/lifxlan/msgtypes.py", line 19, in __init__
2023-01-01 13:17:46,085 Thread-2527 udi_interface      ERROR    udi_interface:write: super(GetService, self).__init__(MSG_IDS[GetService], target_addr, source_id, seq_num, ack_requested, response_requested)
2023-01-01 13:17:46,085 Thread-2527 udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026038_7/.local/lib/python3.9/site-packages/lifxlan/message.py", line 43, in __init__
2023-01-01 13:17:46,086 Thread-2527 udi_interface      ERROR    udi_interface:write: self.packed_message = self.generate_packed_message()
2023-01-01 13:17:46,086 Thread-2527 udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026038_7/.local/lib/python3.9/site-packages/lifxlan/message.py", line 47, in generate_packed_message
2023-01-01 13:17:46,086 Thread-2527 udi_interface      ERROR    udi_interface:write: self.header = self.get_header()
2023-01-01 13:17:46,086 Thread-2527 udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026038_7/.local/lib/python3.9/site-packages/lifxlan/message.py", line 55, in get_header
2023-01-01 13:17:46,086 Thread-2527 udi_interface      ERROR    udi_interface:write: frame_addr = self.get_frame_addr()
2023-01-01 13:17:46,086 Thread-2527 udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026038_7/.local/lib/python3.9/site-packages/lifxlan/message.py", line 80, in get_frame_addr
2023-01-01 13:17:46,087 Thread-2527 udi_interface      ERROR    udi_interface:write: mac_addr = little_endian(bitstring.pack(mac_addr_format, convert_MAC_to_int(self.target_addr)))
2023-01-01 13:17:46,087 Thread-2527 udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026038_7/.local/lib/python3.9/site-packages/bitstring.py", line 4689, in pack
2023-01-01 13:17:46,088 Thread-2527 udi_interface      ERROR    udi_interface:write: s._addright(BitStream._init_with_token(name, length, value))
2023-01-01 13:17:46,088 Thread-2527 udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026038_7/.local/lib/python3.9/site-packages/bitstring.py", line 1435, in _init_with_token
2023-01-01 13:17:46,089 Thread-2527 udi_interface      ERROR    udi_interface:write: raise CreationError(f"Token with length {token_length} packed with value of length {b.len} "
2023-01-01 13:17:46,089 Thread-2527 udi_interface      ERROR    udi_interface:write: bitstring
2023-01-01 13:17:46,089 Thread-2527 udi_interface      ERROR    udi_interface:write: .
2023-01-01 13:17:46,089 Thread-2527 udi_interface      ERROR    udi_interface:write: CreationError
2023-01-01 13:17:46,089 Thread-2527 udi_interface      ERROR    udi_interface:write: :
2023-01-01 13:17:46,089 Thread-2527 udi_interface      ERROR    udi_interface:write: Token with length 64 packed with value of length 0 (bits:64=0).
2023-01-01 13:17:53,299 MQTT       udi_interface.interface DEBUG    interface:_message: QUEUING incoming message shortPoll
Edited by garybixler
Solved by xKing
@xKing
Hi, after checking my network and access points LiFX is still unable to do a discovery. Still produces the above errors.
Using the eisy on Ethernet.
eisy  5.5.2,  PG3 3.1.18
I have the same issue on eisy v5.5.3 \ v3.1.18.  I assume since the auto discovery fails the DB object is never correctly created.
I added a devlist file using the serial number for mac as recommended for firmware 3.7+ and the node is created.  Unfortunately the status is always shown as offline and commands always fail.  I created static addresses in my router since mac and serial numbers are no longer the same.
2023-01-14 14:17:10,559 Command udi_interface.interface ERROR interface:_handleInput: _parseInput: node address d073d56ade00 does not exist. {'address': 'd073d56ade00', 'cmd': 'DON', 'query': {}}
Has anyone heard back from @xKing and/or has anyone found a solution for the Lifx Node Server to work with ZMatter on eisy ?
While waiting for a solution, I am trying to use Home Assistant.
I would like to duplicate on HA a program that I have on eisy (not working because of Lifx Node Server not being recognized) :
IF
From Sunset to 10 pm
THEN
Lifx 1 = ON at 100% and color Blue
Lifx 2 = ON at 100% and color Blue
Lifx 1 = ON at 100% and color White
Lifx 2 = ON at 100% and color White
Wait 10 seconds
Lifx 1 = OFF
Lifx 2 = OFF
Anyone knows how to make this automation on HA (while waiting for ISY Lifx Node Server to work) ?
@asbril  I don't have any of the bulbs, but here are some building blocks for you... First, you need 2  automatons.
First automation:
Trigger: sun @sunset
conditions: none
Actions: Whatever "Device" actions you need to turn the bulbs to 100% blue
Second automation:
Trigger:  Time: at 10:00PM
Conditions: none
Actions: Whatever "Device" actions you need to turn the bulbs on 100% White
               Wait 10 seconds
               Whatever "Device" actions you need to turn the bulbs off.
so original LiFX integration is based on LifxLAN python project that was abandoned for a few years, one of the libraries it depends on updated and broke it
you can work around that by doing something like this:
sudo -u polyglot bash
pip3 uninstall bitstring
pip3 install bitstring==3.1.9
I don't know if LifxLAN author is going to update their library...
@xKing
I tried the suggested SSH commands but no difference. I still get the string of errors when doing a re-discover. Also tried reinstalling the NS.
eisy 5.5.4
I redid the commands and copied the results.
[polyglot@eisy /usr/home/admin]$ pip3 uninstall bitstring
Found existing installation: bitstring 3.1.9
Uninstalling bitstring-3.1.9:
  Would remove:
    /var/polyglot/.local/lib/python3.9/site-packages/bitstring-3.1.9.dist-info/*
    /var/polyglot/.local/lib/python3.9/site-packages/bitstring.py
Proceed (Y/n)? y
  Successfully uninstalled bitstring-3.1.9
[polyglot@eisy /usr/home/admin]$ pip3 install bitstring==3.1.9
Defaulting to user installation because normal site-packages is not writeable
Collecting bitstring==3.1.9
  Using cached bitstring-3.1.9-py3-none-any.whl (38 kB)
Installing collected packages: bitstring
Successfully installed bitstring-3.1.9
2023-01-20 09:35:05,585 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING command
2023-01-20 09:35:05,586 Thread-106 udi_interface INFO lifx-poly:_discovery_process: Starting LiFX Discovery thread...
2023-01-20 09:35:05,587 Thread-106 udi_interface ERROR udi_interface:write: Exception in thread
2023-01-20 09:35:05,587 Thread-106 udi_interface ERROR udi_interface:write: Thread-106
2023-01-20 09:35:05,587 Thread-106 udi_interface ERROR udi_interface:write: :
2023-01-20 09:35:05,587 Thread-106 udi_interface ERROR udi_interface:write: Traceback (most recent call last):
2023-01-20 09:35:05,587 Thread-106 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.9/threading.py", line 980, in _bootstrap_inner
2023-01-20 09:35:05,588 Thread-106 udi_interface ERROR udi_interface:write: self.run()
2023-01-20 09:35:05,588 Thread-106 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.9/threading.py", line 917, in run
2023-01-20 09:35:05,588 Thread-106 udi_interface ERROR udi_interface:write: self._target(*self._args, **self._kwargs)
2023-01-20 09:35:05,588 Thread-106 udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026038_7/lifx-poly.py", line 206, in _discovery_process
2023-01-20 09:35:05,589 Thread-106 udi_interface ERROR udi_interface:write: devices = self.lifxLan.get_lights()
2023-01-20 09:35:05,589 Thread-106 udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026038_7/.local/lib/python3.9/site-packages/lifxlan/lifxlan.py", line 42, in get_lights
2023-01-20 09:35:05,589 Thread-106 udi_interface ERROR udi_interface:write: self.discover_devices()
2023-01-20 09:35:05,589 Thread-106 udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026038_7/.local/lib/python3.9/site-packages/lifxlan/lifxlan.py", line 50, in discover_devices
2023-01-20 09:35:05,589 Thread-106 udi_interface ERROR udi_interface:write: responses = self.broadcast_with_resp(GetService, StateService,)
2023-01-20 09:35:05,589 Thread-106 udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026038_7/.local/lib/python3.9/site-packages/lifxlan/lifxlan.py", line 234, in broadcast_with_resp
2023-01-20 09:35:05,590 Thread-106 udi_interface ERROR udi_interface:write: msg = msg_type(BROADCAST_MAC, self.source_id, seq_num=0, payload=payload, ack_requested=False, response_requested=True)
2023-01-20 09:35:05,590 Thread-106 udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026038_7/.local/lib/python3.9/site-packages/lifxlan/msgtypes.py", line 19, in __init__
2023-01-20 09:35:05,590 Thread-106 udi_interface ERROR udi_interface:write: super(GetService, self).__init__(MSG_IDS[GetService], target_addr, source_id, seq_num, ack_requested, response_requested)
2023-01-20 09:35:05,590 Thread-106 udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026038_7/.local/lib/python3.9/site-packages/lifxlan/message.py", line 43, in __init__
2023-01-20 09:35:05,590 Thread-106 udi_interface ERROR udi_interface:write: self.packed_message = self.generate_packed_message()
2023-01-20 09:35:05,591 Thread-106 udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026038_7/.local/lib/python3.9/site-packages/lifxlan/message.py", line 47, in generate_packed_message
2023-01-20 09:35:05,591 Thread-106 udi_interface ERROR udi_interface:write: self.header = self.get_header()
2023-01-20 09:35:05,591 Thread-106 udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026038_7/.local/lib/python3.9/site-packages/lifxlan/message.py", line 55, in get_header
2023-01-20 09:35:05,591 Thread-106 udi_interface ERROR udi_interface:write: frame_addr = self.get_frame_addr()
2023-01-20 09:35:05,591 Thread-106 udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026038_7/.local/lib/python3.9/site-packages/lifxlan/message.py", line 80, in get_frame_addr
2023-01-20 09:35:05,591 Thread-106 udi_interface ERROR udi_interface:write: mac_addr = little_endian(bitstring.pack(mac_addr_format, convert_MAC_to_int(self.target_addr)))
2023-01-20 09:35:05,592 Thread-106 udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026038_7/.local/lib/python3.9/site-packages/bitstring.py", line 4689, in pack
2023-01-20 09:35:05,593 Thread-106 udi_interface ERROR udi_interface:write: s._addright(BitStream._init_with_token(name, length, value))
2023-01-20 09:35:05,593 Thread-106 udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026038_7/.local/lib/python3.9/site-packages/bitstring.py", line 1435, in _init_with_token
2023-01-20 09:35:05,594 Thread-106 udi_interface ERROR udi_interface:write: raise CreationError(f"Token with length {token_length} packed with value of length {b.len} "
2023-01-20 09:35:05,594 Thread-106 udi_interface ERROR udi_interface:write: bitstring
2023-01-20 09:35:05,594 Thread-106 udi_interface ERROR udi_interface:write: .
2023-01-20 09:35:05,594 Thread-106 udi_interface ERROR udi_interface:write: CreationError
2023-01-20 09:35:05,594 Thread-106 udi_interface ERROR udi_interface:write: :
2023-01-20 09:35:05,594 Thread-106 udi_interface ERROR udi_interface:write: Token with length 64 packed with value of length 0 (bits:64=0).
Ah I see, polyglot 3 uses separate package repo for each node server - in this case /var/polyglot/pg3/ns/0021b9026038_7/.local/lib/python3.9/site-packages/bitstring.py is unique for LiFX install. I'll need to look around to see how to make it downgrade :) I'm still on PG2 myself :D
Good News. After doing the SSH commands and restarting the NS it discovered the bulbs.
Thanks so much.
Gary
Probably can change requirements to point to specific version? Not >=.
@xKing
=============Update=============
Update 1/21/2023
The file structure for Polisy is slightly different than the eisy use the following to replace bitstring on a Polisy.
pip3 uninstall --prefix /var/polyglot/.local bitstring
pip3 install --prefix /var/polyglot/.local bitstring==3.1.9
===============Original Problem============
I've tried the suggested uninstall / install you listed above and am still have some issues. Can you point me in the right direction? This is on a Polisy running 5.5.4.
2023-01-20 14:05:58,036 MainThread udi_interface      INFO     polylogger:set_basic_config: set_basic_config: enable=True level=30
2023-01-20 14:06:00,769 MainThread udi_interface      INFO     __init__:<module>: UDI Python Interface for Polyglot version 3 3.0.46 Starting...
2023-01-20 14:06:00,835 MainThread udi_interface      ERROR    udi_interface:write: Traceback (most recent call last):
2023-01-20 14:06:00,836 MainThread udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/000db9560fac_3/./lifx-poly.py", line 10, in <module>
2023-01-20 14:06:00,838 MainThread udi_interface      ERROR    udi_interface:write: import lifxlan
2023-01-20 14:06:00,839 MainThread udi_interface      ERROR    udi_interface:write: File "/var/polyglot/.local/lib/python3.9/site-packages/lifxlan/__init__.py", line 1, in <module>
2023-01-20 14:06:00,841 MainThread udi_interface      ERROR    udi_interface:write: from .lifxlan import LifxLAN
2023-01-20 14:06:00,841 MainThread udi_interface      ERROR    udi_interface:write: File "/var/polyglot/.local/lib/python3.9/site-packages/lifxlan/lifxlan.py", line 10, in <module>
2023-01-20 14:06:00,843 MainThread udi_interface      ERROR    udi_interface:write: from .device import DEFAULT_ATTEMPTS, DEFAULT_TIMEOUT, Device, UDP_BROADCAST_IP_ADDRS, UDP_BROADCAST_PORT
2023-01-20 14:06:00,844 MainThread udi_interface      ERROR    udi_interface:write: File "/var/polyglot/.local/lib/python3.9/site-packages/lifxlan/device.py", line 29, in <module>
2023-01-20 14:06:00,845 MainThread udi_interface      ERROR    udi_interface:write: from .msgtypes import Acknowledgement, GetGroup, GetHostFirmware, GetInfo, GetLabel, GetLocation, GetPower, GetVersion, \
2023-01-20 14:06:00,846 MainThread udi_interface      ERROR    udi_interface:write: File "/var/polyglot/.local/lib/python3.9/site-packages/lifxlan/msgtypes.py", line 9, in <module>
2023-01-20 14:06:00,848 MainThread udi_interface      ERROR    udi_interface:write: import bitstring
2023-01-20 14:06:00,849 MainThread udi_interface      ERROR    udi_interface:write: ModuleNotFoundError
2023-01-20 14:06:00,849 MainThread udi_interface      ERROR    udi_interface:write: :
2023-01-20 14:06:00,850 MainThread udi_interface      ERROR    udi_interface:write: No module named 'bitstring'
[polyglot@polisy ~]$ pip3 install --prefix /var/polyglot/pg3/ns/000db9560fac_3/.local bitstring==3.1.9
  Attempting uninstall: bitstring
    Found existing installation: bitstring 4.0.1
    Uninstalling bitstring-4.0.1:
      Successfully uninstalled bitstring-4.0.1
Edited by kzboray
