Insteon RemoteLinc
I am using an ISY 994 ir pro running on v5.3.4 with mostly Insteon and some X-10. I have a couple of Insteon RemoteLincs . They link and respond to On / OFF commands in my programs. My issue is that I cannot figure out if the Bright / Dim/ All On /All OFF can be programmed. I don't see options in the program screen for using them. What am I missing?
Solved by xlurkr
All On and All Off cannot be programmed as far as I know. They simply act on all of the devices linked to the RemotLinc. I don't use dim and bright much but I assume they act on the devices associated with the last button you pressed on the RemoteLinc. I'll give it a try and confirm that this evening.
Thanks guys. So the answer then is no, those buttons only work on Insteon responders that were already directly accessed by that RemoteLinc.
Create a scene that duplicates the devices and control it.
I already have a program that turns lights on and off with the RemoteLinc buttons 1 - 6. My issue is that the ISY doesn't seem to have a way to recognize other than the 6 (12) buttons. The idea was simple, use the Bright / Dim buttons to execute that command for X-10 devices. It looks like that isn't possible.
I have a vague recollection of trying this myself years ago, and you're right, those buttons can't do anything except control the Insteon devices linked to that remote.  No programming.
-Tom
