last run time
How do you use the last run time?
I would like to use this for 2 motion sensors.
This way I could tell if some one is coming out
or in the side walk beside the house.
Any ideas?
Hello south,
You can use the last run time of a program as conditions in your other programs and evaluate the elapsed time.
Any ideas?
This is what I have:
From last run time for "Coming in"
for 1 minute
But does not seem to work, am I missing something?
Or do I need to add something??
Does the last run time have to be precise or can it vary?
Most people walk at a different pace so the time will be different.
Is there a way to compensate for this?
Hello south,
You can select a From | For for Last Run Time.
       From    Last Run Time for 'Motion On'
       For      30 seconds
