eisy/Elk node server settings
Not having had any experience with PG3x, or node servers for that matter, I'm have some setup issues connecting my Elk M1 to the eisy. It sure was "eisy-er" on my tried and true 994i with the Elk plug-in! I've installed the ELK node server and it shows as "connected" and the "M1EXP status" is "connected" in the eisy but it's not pulling any data from the M1. the import from my 994 brought over all of my lighting but not my "area 1" nodes. I've set the port to 2101, the non-secure port. I've set the "user_code to my M1 password.
It's not the password, it's a ELK user code like the one you use at the panel. I created a unique one specifically for PG3.
Also, remember you are using eisy and a version of PG3 that's had many recent changes so there are bound to be issues. Also, the ELK NS has had very little testing on eisy. My eisy is having issues right now so I'm unable to test...
There's is an issue with the ELK node server running on PG3 right now but am hoping it will be resolved on Monday. How ever I am able to get full functionality. Is the host actually elk://192.168.1.251:2601 ?
I'm wondering if I should delete the M1 node server from the eisy and re-install it.
I've set the host to 192.168.1.251:2101 since I read that it uses the non-secure port.
PG3x Version 3.1.18
Status: Connected
Frontend Version: 3.1.18
IoX Version: 5.5.2   Connected
Uptime: 41 Minute(s) 15 Second(s)
(c) 2023 UDI
