Admin Console on Different Subnet
Is there a way to access the admin console via a different subnet? I can’t access the console even when I manually type in the IoX ip.
Solved by Geddy
@endobiker do you have firewall between the subnet blocking traffic? It would probably be easier to use the portal process to access as though you were remote. You probably don’t have traffic configured to cross between the two.
Directions: https://wiki.universal-devices.com/index.php?title=ISY_Portal_Admin_Console
Discovery won't work on a different subnet unless something explicitly passing discovery packets. But entering manual should definitely work. Try to test it with telnet or browser. If you type "https://xxxx:8443/desc" into browser, it should work. As said above, likely firewall from your PC to your Polisy/eisy is not open.
I had a firewall allowing my computer to access Polisy but not the reverse. Added it and it worked. Thank you for the help.
