EISY migration issue (failure to run)
Most of my node servers came across from my POLISY to the EISY except for two ; one of them being OpenSprinkler.
In the logs it seems to be having a sslv3 alert handshake failure.  Logs attached.
Also the restore from backup did not bring back the configuration on this node server and two others.  Most did.
OpenSprinkler_1-9-2023_104107-AM.zip
Solved by sjenkins
Thanks, both of the node servers I published need to be updated to support pg3,  hopefully by the end of the day today.
@Javi I did do that the first time (had to do it with all my ns coming over).
I just did it again.  Also have done both a restart of pg3x and then a restart of whole eisy.
Same error with the issue.  I don't have much in the way of programming for this ns so I am ok to delete and install in a different spot or anything else to "play" with it.
Let me know ; I'll leave it stopped for now.
@Javi so I deleted the node server &. installed it in another slot.
All 34 nodes came back.  Solved.
Thanks again!
Thanks again!
Great.  Maybe migration related?
Looks like it.  I think as long as people have a list of things to try we can get everyone through this.  No doubt by deleting I reset something ; maybe didn't need to change slots.  Thanks again for your updates.
Today I have been into my z-wave migration so it was good to have a base system which was working as before.
