Keyboard digits 0-9 don't work
For some reason the node server doesn't like anything mapped to keys 0-9.
Easy to work around by mapping to other keys (e.g. F1-F10).  So possibly doesn't need to be fixed, just documented not to use them.
Other than that, it works great for me.  Thanks for developing!
I've been working with the 40 default ISY IR codes.  Once I get the last 5 added to flirc and tested, I'll provide the flirc config file and keyboard mappings so others won't have to go through the trouble of that step (if you're converting from using ISY IR).
What Flirc profile are you using and have you tried another remote with 0-9? The logic is pretty straightforward. It should send something if Flirc sending key presses at all. You can PM the logs and I'll take a look. Just note down the time when you're pressing those.
