Cannot Discover Devices
Go to solution Solved by bradshawkyle,
4 hours ago, Jimbo.Automates said:
Is your eisy using only a wired Ethernet connection? And is it on the same LAN? Some have segmented their lan which causes discover to fail.
The smart bulbs are on a 2.4gHz network, eISY was wireless on 5gHz.  I've read about people having problems accessing devices on the same network, but different bands.  Just to be safe, I moved eISY to 2.4, reinstalled the node server, but no luck. I'm currently running the Honeywell Home node server to access two wireless thermostats with no problems.
Link to comment
Yes, but does the Honeywell NS use a discovery to find thermostats or are they manually entered? There was/is a problem with the way an IP address is defined on eisy when using WiFi which causes problems for some NS like this one. Please download log package and PM it to me and also let me know the IP address of one Kasa device.
Link to comment
Goo d point on how Honeywell is configured, you point the Node Server to an API you have to create on the Honeywell side. I forgot about that.  IP address for one Kasa device is 10.0.5.87. Log file is attached.  Also, thank you very much for your help!
Kasa_1-31-2023_84102-AM.zip
Link to comment
      36.9k
      370.2k
