Lamplinc dual band
Is there a way to use the control command with a lamplinc dual band? I would like to be able to tell if the lamp was turned on manually rather than through a program or scene. I have it set to turn on and off by a motion detector or override the motion detector if I use a button on a kpl. I have the lamplinc dual crosslinked with the kpl button. Thanks for any ideas.
Hi drglenn,
Yes, absolutely. All new LampLincs (especially the dual band one) have sense feature which means that:
1. You can use Control - on/off/dim/brighten/fast on/fast off in programs
2. Use the device as controller in a scene. This way, if someone manually turns on the LL, the responders in the scene for which the LL is a controller shall respond accordingly
