Installed, added pushover keys, red exclamation within AC
NS shows up in AC, when I add Pushover keys I get the red exclamation!  Am I doing something wrong?
image.jpeg.857a88520223473a4272ea1aa8589b87.jpegimage.thumb.jpeg.90443e9fabf5f4d18712c23537b83296.jpeg
Yeah I should have known to do that!
I see:
2/13/2023, 12:15:20 [pg3] info: IoX entry for Notification::2 OK
2/13/2023, 12:16:10 [pg3] info: [00:21:b9:02:5f:c0_2] Retrieved customparams
2/13/2023, 12:16:10 [pg3] info: [00:21:b9:02:5f:c0_2] Retrieved customparamsdoc
2/13/2023, 12:16:10 [pg3] info: [00:21:b9:02:5f:c0_2] Retrieved customtypedparams
2/13/2023, 12:16:10 [pg3] info: [00:21:b9:02:5f:c0_2] Retrieved customtypeddata
2/13/2023, 12:16:10 [pg3] info: [00:21:b9:02:5f:c0_2] Retrieved notices
2/13/2023, 12:16:10 [pg3] info: [00:21:b9:02:5f:c0_2] Retrieved oauth
2/13/2023, 12:17:52 [pg3] info: [00:21:b9:02:5f:c0_1] controller reporting command DOF
2/13/2023, 12:20:20 [pg3] info: Verifying node servers are installed on IoX correctly
2/13/2023, 12:20:20 [pg3] info: IoX entry for Ecobee::1 OK
2/13/2023, 12:20:20 [pg3] info: IoX entry for Notification::2 OK
2/13/2023, 12:20:27 [pg3] info: Caught SIGTERM/SIGINT Shutting down.
2/13/2023, 12:20:27 [pg3] info: Stopping running node servers...
2/13/2023, 12:20:27 [pg3] error: uncaughtException: write EPIPE
Error: write EPIPE
    at afterWriteDispatched (node:internal/stream_base_commons:160:15)
    at writeGeneric (node:internal/stream_base_commons:151:3)
    at Socket._writeGeneric (node:net:923:11)
    at Socket._write (node:net:935:8)
    at writeOrBuffer (node:internal/streams/writable:392:12)
    at _write (node:internal/streams/writable:333:10)
    at Writable.write (node:internal/streams/writable:337:10)
    at Console.log (/var/polyglot/node_modules/winston/lib/winston/transports/console.js:79:23)
    at Console._write (/var/polyglot/node_modules/winston-transport/index.js:103:17)
    at doWrite (/var/polyglot/node_modules/readable-stream/lib/_stream_writable.js:409:139)
    at writeOrBuffer (/var/polyglot/node_modules/readable-stream/lib/_stream_writable.js:398:5)
    at Writable.write (/var/polyglot/node_modules/readable-stream/lib/_stream_writable.js:307:11)
    at DerivedLogger.ondata (/var/polyglot/node_modules/readable-stream/lib/_stream_readable.js:681:20)
    at DerivedLogger.emit (node:events:525:35)
    at addChunk (/var/polyglot/node_modules/readable-stream/lib/_stream_readable.js:298:12)
    at readableAddChunk (/var/polyglot/node_modules/readable-stream/lib/_stream_readable.js:280:11)
I can attach more log, if needed.
