eisy and OpenHab 3 Websockets error
In the past, I've integrated my ISY994i Insteon devices with Openhab 3 and everything worked great. Now, with my brand new eisy, the integration does not work. With the OH ISY binding, I can create the ISY bridge and that indicates that it is "on line". However, I have this error in the OH log and none of the discovered devices will work.
[ERROR] [sy.internal.IsyWebSocketSubscription] - Error parsing message [<?xml version="1.0"?><Event seqnum="57" sid="uuid:49"><control>_5</control><action>1</action><node></node><eventInfo></eventInfo></Event>]
Since this worked with ISY994i, I'm assuming this problem originates on the eisy?? Any insight will be helpful. Perhaps I'm missing a required node server?
Thank you.
I don't use OH but from the error message it appears OH has a parser which is crashing on this <Event>. This would have to be reported to whom ever maintains the ISY binding as it is not limited to eisy.
Based on other third party integrations, some users had issues as the port changed. eisy is port 8080 , ISY994 is port 80.
Ok thank you. The maintainer of the OH ISY Binding hasn't posted any updates since the initial release 2 years ago. Not sure if it's actually being maintained. But, I've started to play with Home Assistant as the ISY integration seems to work without issues. One question I have regarding eisy and Z-wavimage.jpeg.4965c63960eb1d5c1a336a054a5e0004.jpege. When I add a Zooz z-wave switch to eisy, the following items are added also. I'm not sure what this is all about. They also show up in Home Assistant as "discovered" devices. Not sure if I'm missing something. This is my first foray into isy and z-wave.
Again, thanks for any additional information!
This isn't OpenHab related, but what you're seeing is normal for those devices.  See this link:
Thanks everyone for the replies. I was holding off migrating all of my z-wave devices to eisy from OpenHab until I knew what was up with these devices.
