IoX 5.5.7 Not Available for Update from 5.5.6 in UD Mobile(iOS)
@Javi,
I was going to use UD Mobile to update IoX from 5.5.6 to 5.5.7, but 5.5.6 is showing as Up to Date.  When my system was at 5.5.4, UD Mobile showed 5.5.6 available.  I chose to use the AC to do that update.  But this time, I was going to use UD Mobile and 5.5.7 isn't available yet.  Is that a bug or is IoX 5.5.7 really just for eisy.  I'm using Polisy.
Anyone else seeing this?
Solved by Javi
1 hour ago, Geddy said:
@mbking I experienced the same thing last night.  It should give you a force update option.
What version is your app?
I’m using iOS version 1.0.20. I do get the Force Update option, but wanted to wait until it was determined to be a bug so I could test the solution.
Updated today from the Admin Console on my PC with no problem.  Never used the UD Mobile for updates.
Edited by TUhl01
This is by design.  The force update will upgrade to the latest version even when not showing as available. Think of this as staged rollout, with those following the forum having the ability to jump to the top of the list with a forced upgrade.
Note: this is the same as upgrade from AC.
