I can't logon to the Admin console and MobiLinc says I have no devices
Solved by Geddy
The default admin logon worked. Then I had to restore from a recent backup. What caused this? Do I need to upgrade to replace something?
21 minutes ago, PapaBear said:
How much storage capacity does the SD does it need?
From the wiki
[NOTE: The ISY994i takes a MicroSD card. The max size is 32GB. Please look for a card with the newer A1 rating (A2 also works, but will fallback to A1 because the ISY994 does not provide hardware support required for A2). All other process steps below remain the same.]
The wiki also outlines the process for proper replacement and reinstalling firmware.
