Migrate from PG3 backup
I saved the backup on my Polisy, and trying to migrate from PG3 backup on my eisy.
3/11/2023, 15:05:00 [pg3] info: Processing: {"method":"POST","url":"/frontend/restoreFromPG3","header":{"host":"192.168.86.89:3000","connection":"keep-alive","content-length":"1321","accept":"application/json, text/plain, */*","authorization":"Bearer eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJkYXRhIjp7Im5hbWUiOiJhZG1pbiIsInBhc3N3b3JkIjoiYWRtaW4iLCJpZCI6IjEwMCIsInJvbGUiOiJhZG1pbiIsImdyb3VwcyI6IltcIkFkbWluaXN0cmF0b3JzXCJdIiwiZW5hYmxlZCI6MX0sImlhdCI6MTY3ODU3NTg0NywiZXhwIjoxNjc5MTgwNjQ3fQ.iyy8rxV3f3FVXLYV8CL_TGGuH0d6iVz_6csNEhycfBI","user-agent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/110.0.0.0 Safari/537.36","content-type":"multipart/form-data; boundary=----WebKitFormBoundaryyNcgYSqNrR132KLi","origin":"http://192.168.86.89:3000","referer":"http://192.168.86.89:3000/backup","accept-encoding":"gzip, deflate","accept-language":"en-US,en;q=0.9"}}
3/11/2023, 15:05:00 [pg3] error: RestoreFromPG3: Error: FILE_ENDED
    at PullStream.pull (/var/polyglot/node_modules/unzipper/lib/PullStream.js:83:28)
    at PullStream.emit (node:events:513:28)
    at PullStream.<anonymous> (/var/polyglot/node_modules/unzipper/lib/PullStream.js:20:10)
    at PullStream.emit (node:events:525:35)
    at finish (node:internal/streams/writable:748:10)
    at node:internal/streams/writable:726:13
    at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
All packages were updated this morning, and migrated from Polisy.
10 minutes ago, Jimbo.Automates said:
Well crap... pg3 backup zip file is corrupt...
This comes a little late to help you, but I take two back up before I migrate, over two days to try to avoid that. I did that for both locations I migrated.
It didn't matter how many times backup was run, they were all corrupt.  But I was able to open the file and view the contents which showed a PG3 error due to an invalid soft link I had created a while back while debugging an issue.
