Forwarding Ports with Airport Extreme
rudyonrails
I tried setting up my ISY-99i unit yesterday. I believe I have everything wired correctly. Port caple to PLM in the wall. Internet Cable to my Airport Extreme router. I am getting the "FAILED to connect to Internet Prompt" when trying to enable internet.
I have posted some snapshots on flickr:
http://www.flickr.com/photos/rudyonrails/
**I think my problem is my Port Forwarding from AE to ISY.
I can't seem to discover devices when going to http://10.0.1.2
Can you help?
Hello rudyonrails,
If you have set up port forwarding in your router you do not need to use Enable Internet Access on the ISY.
According to your screen shot you should be able to access the ISY at http://10.0.1.201.
Rand
Can you help?
Hi rudyonrails (nice!),
Please take the following into consideration:
1. Apple routers do not support UPnP ... so, you cannot use File | Enable Internet Access from the Admin Console
2. If your Airport is connected to another router/modem, then what you have to do is to disable Airport from distributing IP addresses. Otherwise, both your Linksys and your Airport are going to distribute IP addresses and thus cause a conflict
3. Finally, you will have to do manual port forwarding from your router to ISY the instructions for which you will find here:
http://www.universal-devices.com/mwiki/ ... PnP_Router
      38.2k
      381.2k
