2420m expiry time
I've never set my 2420's to time out other than the default time. I recently tried to change the default time on 2 of them from the options dialog. I set one for 5 minutes and one for 8 minutes. However they both remain at the default time.
When I go back to the options menu I put them in linking mode, ISY goes out to query them, and it returns with the appropriate values (5min and 8min) but even so they send an off command after the default 1min. I can't seem to make them last longer than 1min.
Any idea what to check with this?
mark
How old are they, what rev? Do they have adjustment pot.'s for dusk/dawn and time out? If so is jumper 5 on both pins?
Tim
They are reasonably new (past 6 months) - rev 2.0
They have adjustment pots but I don't have any jumpers on.
My 2420 manual shows
J1 - sensitivity
J2 - disable LED
J3 - night-only
J4 - on-only
J5 - not used.
ahhh...
Thank you.
You prompted me to look on smarthome.com - There's a newer manual for the rev 2.0 which shows J5 jumpered for remote management.
Much appreciated!
Mark
