994 and PLM Status After Upgrade
Preparing for my 994 to EISY upgrade.
W/ a new EISY and USB PLM, after I run the upgrade process.  What is the status of the 994 and old PLM?  Do I factory reset them and then can use as a separate system?
Solved by DennisC
With a serial adapter wiring kit that UD offers, the PLM can be a spare for eisy.
As for the ISY, it is at end of life, but you can use it as you wish.
Right, but how do I properly reset the 994 and the serial PLM so they no longer have links to the original deviceS?
Factory Reset ISY
Use a sharp object to push in the Reset Button till the RX, TX, Mem, Error lights start blinking (every second)
Hold for at least 30 seconds until all of the the RX, TX, Mem, Error lights turn off and Mem light starts flashing quickly
Release and wait for system reboot (reboot is complete when Mem light stops flashing)
Factory Reset PLM
Remove PLM from power for at least 10 seconds. Press the black set button and continue to hold it while you insert it back into the 120 VAC power.
