UD Mobile iOS V1.0.29 Crashes
Updated to 1.0.29 and now UD Mobile iOS crashes attempting to start the app.
Solved by Javi
I think I see your crash report.  Looking into this now.
XCode (iOS development) was updated and required dependency updates also which may be the cause.
@mbking,
Do you happen to have an app backup file?   This looks like something in Favorites are causing the crash. It will be much easier to locate if I have the setup.
Edit: Replicated issue and removed from test flight.  I think you can downgrade the version, but only attempt if you have a backup file...I have not attempted this before so am unsure if it is destructive.
Edit 2: Should be fixed in version 1.0.30
@Javi, I downgraded without issue.  I'll look for the new version.  Thanks!
@Geddy, Looks like it's something with my Favorites setup.  I'm running iOS 16.4.1 on a 14 Pro.
Great!
5 hours ago, Geddy said:
@Javi are you pushing 1.0.30 to test flight? Showing 1.0.28 currently. I know it might take some time, but didn't want to downgrade if it's pushing soon. Thanks!
Just awaiting Apple's Approval.
