Signal and Transmit power not showing up for Outdoor Probe
I have two of them so its not a probe issue.  See screenshots
All other tags are showing it but they are normal indoor tags
1 hour ago, DennisC said:
Do they show up directly in the wireless tag hub via cao tag website?
Transmit Power does not show up on any of the tags on the website (including the ones that work in the Nodeserver).  Its not something they seem to offer there.   So if it cant display for all types of tags then remove the field.
But Signal DOES show up for the ones not showing up.  See screenshot
One thing it does show on the website that would be great on the nodesever for tags that use probes is probe type.  There is a bug (and they know it) where sometimes the probe type changes to another type.  I have to go into the app and change it back to the one I have.  That would be great to run a program- If probe type is XXXXX then change back to the one I have.
Developer said you not using correct API info for the pro
I see this in log
023-05-08 15:29:54,827 Thread-12 udi_interface.node ERROR node:setDriver: 03b09cf3705dad:HotTub Invalid driver: CC
2023-05-08 15:29:54,829 Thread-12 udi_interface.node ERROR node:setDriver: 03b09cf3705dad:HotTub Invalid driver: GV16
2023-05-08 15:30:31,259 Thread-12 udi_interface.node ERROR node:setDriver: 528abefa36afaf:Aquarium Invalid driver: CC
2023-05-08 15:30:31,260 Thread-12 udi_interface.node ERROR node:setDriver: 528abefa36afaf:Aquarium Invalid driver: GV16
as you can see in the Beverage Fridge picture it does work for tags.
Developer (Mike) said the Web Version gets the same data so something is wrong or the wrong driver.
Also one other thing.  Notice the LAST UPDATE TIME on the Beverage Fridge.  Why cant you convert that to time?  Or maybe its just too hard to convert
