Upgrading to EISY
I recently upgraded my system to the Polisy after installing the z-wave z-matter board.  I seem to do this right after there is a major system upgrade.   I would like to hopefully do a final upgrade.  In addition to the z-wave / z-matter upgrade, I am using a 2413s rev 2.4 0318 with a spare 2413s Rev 2.5 4718 on the shelf.  In addition to the EISY I would have to purchase the USB enclosure for the z-wave/z-matter board as well as the connecting cable for the 2413.  Are there any other pieces/parts I should be ordering?  Also, are these parts available for immediate delivery or is there a backorder issue.
Thanks for your help,
Ron
Solved by Techman
The parts you mentioned are all that's needed. I believe that the enclosure for the Zmatter board is currently out of stock.
Instead of buying the cable kit you might want to buy a USB PLM, which is currently in stock at Insteon, either way is workable.
Can someone supply a link to the UDI parts catalog?
The very first post of this subforum has links throughout that will take you to the store. Typing ISY store or universal devices store into google will also do the same.
