ST-Inventory Not showing all/any nodes
After installing Ring nodeserver, ST-Inventory stopped displaying nodes.
It was working before.
From Debug Log
2023-05-21 13:37:44 error: NS: Parsing Error: TypeError: Cannot read properties of undefined (reading 'includes')
at Controller.processNetworkResources (/var/polyglot/pg3/ns/0021b9026061_2/Nodes/ControllerNode.js:209:19)
at Controller.onDiscover (/var/polyglot/pg3/ns/0021b9026061_2/Nodes/ControllerNode.js:85:12)
Solved by bpwwer
Bob, it is not counting anything.  Screenshot attached.  I have over 100 Insteon devices and 20+ Z-wave devices.
Is a post like this the best way to get support?
ST-Inventory_5-22-2023_20713_PM.zip
Have you restarted ST-Inventory?  Or you may just be able to do a query on the node.
I believe what happened is that when you installed Ring, you also had to enable remote access.  When remote access was enabled it restarted the IoX.   When IoX restarts, it doesn't remember any of the node server values.
ST-Inventory will only send the counts to IoX when they change and most of those values rarely change.  It doesn't know that the IoX was restarted and that it needs to send everything again.
Query did the trick.
Thank you.  You are a wizard.
