PG3 version 3.1.21 (Polisy) - May 22nd, 2023
Hello all,
We are very happy to introduce PG3 v3.1.21 with bug fixes and new features, see changelog below.
To upgrade PG3:
In the Admin Console, click on Configuration, Upgrade Packages (note, this can take many minutes, depending on how long it's been since you last updated.).
After the upgrade is complete you will need to restart PG3. From PG3 select System-> Restart Polyglot 3.
Once PG3 has restarted, reload /refresh the browser page.
Note that in some cases you may be asked to reboot after the upgrade is complete.
Changelog for 3.1.21
 -  Fix developer API queries.
 -  Add install option to Purchases page and change "(Re)Install" to "Update".
 -  Base call to PG3 cloudlink protocol on UI protocol.
 -  Finish notification support
 -  Add support for incoming POST request from IoX (to handle more complex notifications)
 -  Remove log messages for access_token authentication not needed.
 -  Remove debug output from sale report request.
 -  Remove portal login button from sales report
 -  Clean up login/logout of portal code in html templates.
 -  Portal oauth2 re-write.  UI should now only ask for portal credentials once.
 -  Limit developer sales report to 18 months.
 -  Sort developer sales entries by date
 -  Handle free/trial in developer sales report if no paid options exist.
 -  Update developer sales report to handle changes to API.
 -  rework purchase options to provide developers with more control over pricing.
 -  Decrease maximum log size and compress old log files.
 -  Add support for push notifications to UD Mobile (for PG3 an Node Servers)
 -  Fix bug in git clone when no branch is specified.
 -  Change text on how to update node server.
 -  Change ISY to IoX in UI
