ELK PG3 won't connect
I just noticed my ELK PG3 node server had disconnected and will not start. Attached is the error log file. Any help would be greatly appreciated.
I have deleted the elk node and re-installed it, restarted PG3, no luck still won't run.
PG3 version 3.1.21, IOX version 5.6.0
debug.log
Edited by MBell
spelling
17 hours ago, Jimbo.Automates said:
Sorry, just saw this.  You should post int he specific node server forum for ELk;
https://forum.universal-devices.com/forum/309-elk/
Michel had forwarded my a support ticket similar to this so we may have helped you already?
The issue in the log has happened to a few people and is not a problem with the node server, the recommended fix is to move to PG3x.
I moved to PG3x and this resolved the issue.
thanks,
