rgs455returns Posted April 5, 2010 Share Posted April 5, 2010 I used the ISY to control our sprinkler system last summer which saved us 50% off the water bill and saved thousands of gallons of water! This was done using, ISY programs, ISY Climate Module. IO device Sprinkler control, Input device, and a Vegetronix Soil probe. http://www.vegetronix.com/Soil-Moisture-Probe.phtml ISY has a "Climate Module" that gathered weather information programed to our local Elementary School who has a server and a weather station. I had 6 weather stations to pick from in our community. Every city has stations to choose from. SO we have local weather data Points to make decision points on when to water. We live in Colorado were the weather conditions are dry and windy. I set the ISY program to water everyday if ALL the conditions were met. Did it rain today? If so how much? How hot was it? I have 5 different watering levels based on the temperature from the day before. Is it windy? If it is windy, I would have the system wait until later and try again. Is the soil moisture level calling for water? When it did water, I set-up an email that was sent to me to let me know how much water was applied from the 5 different watering levels as report or confirmation. So the sprinkler system would only water when I had a REAL need for water. This was fun to set-up and easy to use. I had other ISY programs to "test" the sprinklers to make sure they were working correctly as well as the Drip system and sprayers. I used my IPhone to turn "on" sprinkler zones from the yard instead of running back and forth to the garage. The Vegetronix Probe will needed to be placed about 3/4 of an inch "parallel" to the ground, NOT perpendicular or straight into the ground. It will always read 100% wet. This will give you a reading of the water level in the roots. I am using only one sensor which is currently located in the front. The downside of this location which was "planted" in the lawn during spring which turned out to be too wet and a bit shady location. So the voltage range was limited. 5 volts= wet and 4.2 volts= needed water. This became apparent during the heat of August. The best location in the front was too far away to reach. I am going move the sensor to the backyard in a sunny location. I look forward to sharing this with you and your comments. Bill Link to comment Share on other sites More sharing options...
danswatman Posted April 6, 2010 Share Posted April 6, 2010 Bill, Great post, I'm very interested in the details. I'm having to use Homeseer with a sprinkler pro program currently. I would love to see an example of your code and setup, I have the rain8 modules because they have hardware type guaranteed run times. I fear the easy-rain modules might fail on? I've also requested they pick up future data from the weather sites, why water if there is a 100% chance of rain tomorrow? Cheers, Dan Link to comment Share on other sites More sharing options...
rgs455returns Posted April 6, 2010 Author Share Posted April 6, 2010 Dan, Thanks for the note. The weather can be predicted a bit by many of the data points of the Climate Module i.e. Bar pressure and Dew Point. The programs nothing special but I will include some below as an example. The key item for the ISY was that I ran the programs at 11:50 pm because the Climate Module would refresh with new data at Midnight. So I had the watering decision wait 4 hour until the next morning. Keep in mind the decisions are the ones listed in my note above. Did it rain today? This program runs the zones for the medium water level If - No Conditions - (To add one, press 'Schedule' or 'Condition') Then Set 'COM' On Wait 5 seconds Set 'Front West' On Wait 6 minutes Set 'Front West' Off Set 'COM' Off Wait 5 seconds Set 'COM' On Set 'Front East' On Wait 6 minutes Set 'Front East' Off Set 'COM' Off Wait 5 seconds Set 'COM' On Set 'Back East' On Wait 6 minutes Set 'Back East' Off Set 'COM' Off Wait 5 seconds Set 'COM' On Set 'Back South' On Wait 11 minutes Set 'Back South' Off Set 'COM' Off Wait 5 seconds Set 'COM' On Set 'Back North' On Wait 11 minutes Set 'Back North' Off Set 'COM' Off Send Notification to All Else - No Actions - (To add one, press 'Action') I made programs that ran other programs based on a decision. This one ran a low temp program if the probe was ON. It sent an email if no water was needed. If Status 'Input Sensor' is On Then Run Program 'Sprinkler Decision 68' (If) Else Send Notification to All The programs are simple and can be made to your need. Short of sending all of them this gives you the info to set them up for your location on your lawn! I hope this helps! Bill Link to comment Share on other sites More sharing options...
rgs455returns Posted April 6, 2010 Author Share Posted April 6, 2010 I am using a relay board to run a IO Linc 2450. This board converts the Analog input to an ON/OFF. Here is the link to the board: http://www.vegetronix.com/Products/Relay-Boards.phtml Link to comment Share on other sites More sharing options...
danswatman Posted April 6, 2010 Share Posted April 6, 2010 So any thoughts on how to protect the sprinkler from running over? meaning a hard limit on runtime for a zone. Link to comment Share on other sites More sharing options...
rgs455returns Posted April 6, 2010 Author Share Posted April 6, 2010 Dan, I am sorry I don't know your question. I am a bit new too. Link to comment Share on other sites More sharing options...
danswatman Posted April 6, 2010 Share Posted April 6, 2010 Basically what are you using the control the actual sprinkler valve and if you happen to issue an on command and something breaks in the ISY will the sprinkler run forever? Link to comment Share on other sites More sharing options...
rgs455returns Posted April 6, 2010 Author Share Posted April 6, 2010 I am using the SimpleHomeNet EZIO8SA 3011A for the relays. The Inputs do not work on this device. I would suggest using the EZFlora INSTEON/X10 Sprinkler Controller for the relays at a lower cost. YOu will need a 24 VAC power pack. I bought mine at Ace Hardware. As it relates to the input I would use the relay board and IO Linc 2450. The EZFlora can be placed were your current sprinkler box is located. THen the IO Linc can be closer to the soil sensor. I am moving this to the back yard for shorter run of wires to dry areas in the lawn. I have ended the programs with sending an email. This is confirmation that it did in fact finish. I did not have any problems with the programs not running to the end. In the program you can see where I stopped each zone for 5 seconds. This was to provide better water pressure at the valve. The Values come to a complete stop and a better start. This is real nice when YOU have control over what is happening. Link to comment Share on other sites More sharing options...
danswatman Posted April 7, 2010 Share Posted April 7, 2010 Thanks bill I see there is another thread with more technical stuff about the eZflora I see it does have hard programmable timers. I'm excited enough to buy one and try it. Sounds promising though it seems they are not using actual hardware relays which is unfortunate Link to comment Share on other sites More sharing options...
rgs455returns Posted April 8, 2010 Author Share Posted April 8, 2010 I was not aware the EZFlora INSTEON/X10 Sprinkler Controller did not have real relays. Did you check with Smarthome for some other alternatives that would have real relays? Short of 6 or 8 2450s. The EZFlora most likely would handle the load without any trouble. I am just old fashioned about relays. I would also check with the ISY tech team on the use or access to the timers. You can see above how I used the ISY program timing waits. I would run that timer program again with fewer minutes the second time an hour later. It nice to have that full control over the programing! You might have a zone under a tree that is shady and you can skip that zone. It's fun to think about summer! We had 4" of snow this morning! Link to comment Share on other sites More sharing options...
rgs455returns Posted October 29, 2011 Author Share Posted October 29, 2011 Hello, I posted this over a year ago and I had some trouble with the vegrtronics sensor. SO this year I tried the Digitalsun.com sensor. It is a "wireless" sensor which worked well BUT It stopped working a few weeks ago. I wrote the company and I am still waiting for a reply. I can keep you posted on my progress. My lawn never looked better this year! Perfect working levels all summer long! AMAZING. Bill Link to comment Share on other sites More sharing options...
